vcObject
A base class for all objects. A vcObject becomes invalid when the object it represents is deleted. Accessing properties or methods of such vcObject will raise a ValueError telling that it has been invalidated. It is possible to use "IsValid" property to check the state, without raising an exception.
Module: vcFeatures
Children: vcFeature
IsValidBooleanRGets a value that defines if the object contained in this wrapper is still valid.
